[Bio] / FigKernelScripts / make_binary.pl Repository:
View of /FigKernelScripts/make_binary.pl
Revision 1.2 - (download) (as text) (annotate)
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
# Public License.
use FIG;
# Takes an input file of "pins" and turns it into a set of binary connections (that
# can be glued together with cluster_objects)
$usage = "usage: make_binary File > binary";
($file = shift @ARGV) || die $usage;
open(IN,"<$file") || die "aborted";
while (defined($_ = <IN>))
    if (substr($_,-1) eq "\n")
	while ($_ =~ /(\S+),(\S+)/g)
	    $restrict{$1} = $restrict{$2} = 1;
close(IN);
while (defined($line = <IN>))
    if (substr($line,-1) eq "\n")
	chop $line;
	@ids = sort { &FIG::by_fig_id($a,$b) } grep { ! $restrict{$_} } split(/[\t]+/,$line);
	for ($i=0; ($i < $#ids); $i++)
	    $key = "$ids[$i]\t$ids[$i+1]";
	    if (! $seen{$key})
		print "$key\n";
		$seen{$key} = 1;
