[Bio] / FigKernelScripts / make_binary.pl Repository:
View of /FigKernelScripts/make_binary.pl
Mon Dec 1 20:46:40 2003 UTC (16 years, 7 months ago) by efrank
CVS Tags: V00-00-01, merge-trunktag-bobdev_news-2, Root-bobdev_news, merge-bobdev_news-1, caBIG-dataload-0, merge-trunktag-bobdev_news-1, merge-bodev_news-3, efrank-preMakefileToStandardMk, delong-01, delong-02, caBIG-00-00-00, merge-bobdev_news-2, V00-00-00, merge-trunktag-bodev_news-3
Makefile:
All the rest:
use FIG;
# Takes an input file of "pins" and turns it into a set of binary connections (that
# can be glued together with cluster_objects)
$usage = "usage: make_binary File > binary";
($file = shift @ARGV) || die $usage;
open(IN,"<$file") || die "aborted";
while (defined($_ = <IN>))
    if (substr($_,-1) eq "\n")
	while ($_ =~ /(\S+),(\S+)/g)
	    $restrict{$1} = $restrict{$2} = 1;
close(IN);
while (defined($line = <IN>))
    if (substr($line,-1) eq "\n")
	chop $line;
	@ids = sort { &FIG::by_fig_id($a,$b) } grep { ! $restrict{$_} } split(/[\t]+/,$line);
	for ($i=0; ($i < $#ids); $i++)
	    $key = "$ids[$i]\t$ids[$i+1]";
	    if (! $seen{$key})
		print "$key\n";
		$seen{$key} = 1;
