[Bio] / FigKernelScripts / make_annotations_for_sprout.pl Repository:
Log of /FigKernelScripts/make_annotations_for_sprout.pl
Changes since 1.11: +17 -0 lines
Tue Jul 26 20:19:02 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.10: +85 -85 lines
Updated indenting.
Sun Mar 6 03:40:59 2005 UTC (15 years, 1 month ago) by overbeek
CVS Tags: Root-bobdev_news, efrank-preMakefileToStandardMk, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
Changes since 1.9: +5 -2 lines
additions for sprout
Mon Jan 24 19:18:38 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.8: +44 -44 lines
correct concept of user assign in make_annotations_for_sprout
Mon Jan 17 16:23:28 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.7: +7 -0 lines
fix make_annotations
Sat Jan 15 21:55:35 2005 UTC (15 years, 2 months ago) by overbeek
fix ID of PEG in IsTargetOfAnnotation relation
Wed Dec 8 21:28:10 2004 UTC (15 years, 4 months ago) by overbeek
raw time for annotations
Wed Dec 8 20:51:26 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.4: +10 -3 lines
check for nonnumeric timestamps in Annotations
Mon Dec 6 22:08:10 2004 UTC (15 years, 4 months ago) by overbeek
remove duplicates on annotations for Sprout
Mon Oct 11 18:07:51 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.2: +9 -3 lines
Make non-fig entries have unique ids (by manipulating the annotation time).
Sat Sep 25 04:11:21 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.1: +15 -2 lines
Added dumping of non-assignment annotations. -- /gdp
Tue Sep 21 22:56:50 2004 UTC (15 years, 6 months ago) by overbeek
Dump annotations for import to the SPROUT. (Supersedes `make_FIG_annotations_for_sprout.pl`) -- /gdp
