[Bio] / FigKernelScripts / make_SBML_model.pl Repository:
Log of /FigKernelScripts/make_SBML_model.pl
Wed Nov 12 18:29:31 2008 UTC (11 years ago) by dejongh
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
switch to scenario_directory
Fri Jul 27 18:55:10 2007 UTC (12 years, 4 months ago) by formsma
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.4: +16 -0 lines
Added reaction ATPSYN for manual since KEGG doesn't have it - Kevin
Fri Jul 27 13:38:09 2007 UTC (12 years, 4 months ago) by formsma
Updated filename for cofactors.txt to secondary_compounds.txt - Kevin
Mon Jul 23 20:33:49 2007 UTC (12 years, 4 months ago) by formsma
Fixed errors on filehandleing with RASt - Kevin
Fri Jul 20 15:05:54 2007 UTC (12 years, 4 months ago) by formsma
Changes since 1.1: +15 -5 lines
Updated filehandles for use on RAST. Now uses $fig->model_directory() - Kevin
Tue Jul 17 19:11:59 2007 UTC (12 years, 4 months ago) by formsma
Generate a model in SBML format for a given genome automatically - Kevin
