[Bio] / FigKernelScripts / make_PHOBs_for_subsystems.pl Repository:
Log of /FigKernelScripts/make_PHOBs_for_subsystems.pl
Thu May 12 20:38:37 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.3: +11 -4 lines
add tool to generate gene blocks for variation analysis
Mon May 9 02:33:25 2005 UTC (14 years, 7 months ago) by overbeek
Fixed bug in read-open of set.sizes. -- /gdp
Mon May 9 02:09:11 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.1: +22 -7 lines
Added bulletproofing. -- /gdp
Tue May 3 00:09:39 2005 UTC (14 years, 7 months ago) by overbeek
Diff to selected 1.3
add make_PHOBs_for subsystems
