[Bio] / FigKernelScripts / make_IPR_PFAM_GO_attributes.pl Repository:
Log of /FigKernelScripts/make_IPR_PFAM_GO_attributes.pl
Links to mgrast_rel_2008_1110: (view) (download) (as text) (annotate)
Mon Apr 2 18:54:19 2007 UTC (12 years, 10 months ago) by mkubal
Changes since 1.2: +1 -2 lines
fix to score format
Wed Feb 21 00:14:02 2007 UTC (13 years ago) by mkubal
Changes since 1.1: +4 -4 lines
create attribute text files in /vol/seed-attributes/
Wed Feb 21 00:08:58 2007 UTC (13 years ago) by mkubal
