[Bio] / FigKernelScripts / make_CDD_attributes.pl Repository:
Log of /FigKernelScripts/make_CDD_attributes.pl
Links to rast_rel_2008_09_29: (view) (download) (as text) (annotate)
Mon Apr 2 18:55:12 2007 UTC (13 years, 2 months ago) by mkubal
Changes since 1.1: +1 -2 lines
fix to score format
Tue Feb 20 23:03:00 2007 UTC (13 years, 3 months ago) by mkubal
creates attribute text file in /vol/seed-attributes/
