[Bio] / FigKernelScripts / load_sims.pl Repository:
Log of /FigKernelScripts/load_sims.pl
Links to mgrast_dev_05262011: (view) (download) (as text) (annotate)
Thu Feb 16 23:03:37 2006 UTC (14 years, 1 month ago) by olson
Changes since 1.9: +60 -13 lines
If we are loading unmapped files (as generated by make_close -no-map  and make_sim_tab -no-map),
do the mapping before loading into db.
Changes since 1.8: +17 -0 lines
Sun Nov 20 12:32:04 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.7: +5 -5 lines
fixes
Wed Aug 17 19:32:24 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.6: +10 -4 lines
Add table size estimation code for supporting MyISAM.
Wed Aug 17 13:35:44 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.5: +19 -6 lines
more fixes
Wed Aug 17 13:29:22 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.4: +11 -1 lines
postgres fix for sims/closetab stuff
Sun May 29 02:15:42 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.3: +5 -2 lines
Updated tools for functional coupling computation. Replace string
pges with (genome, peg) pairs.
Sat May 7 21:35:12 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.2: +5 -2 lines
minor fix
Sat May 7 21:33:31 2005 UTC (14 years, 10 months ago) by overbeek
take some of the hardwired directories out of BigFC
Sat May 7 20:57:47 2005 UTC (14 years, 10 months ago) by overbeek
add routines for BigFC
