[Bio] / FigKernelScripts / load_sims.pl Repository:
Log of /FigKernelScripts/load_sims.pl
Links to merge-trunktag-bodev_news-3: (view) (download) (as text) (annotate)
Sun May 29 02:15:42 2005 UTC (15 years ago) by olson
Changes since 1.3: +5 -2 lines
Updated tools for functional coupling computation. Replace string
pges with (genome, peg) pairs.
Sat May 7 21:35:12 2005 UTC (15 years ago) by overbeek
Changes since 1.2: +5 -2 lines
minor fix
Sat May 7 21:33:31 2005 UTC (15 years ago) by overbeek
take some of the hardwired directories out of BigFC
Sat May 7 20:57:47 2005 UTC (15 years ago) by overbeek
add routines for BigFC
