[Bio] / FigKernelScripts / load_literature.pl Repository:
Log of /FigKernelScripts/load_literature.pl
Thu Jun 9 05:51:06 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.1: +6 -27 lines
Tue Nov 2 14:45:31 2004 UTC (15 years, 3 months ago) by overbeek
fix bug in subsys.cgi and add Literature to Global
