[Bio] / FigKernelScripts / load_literature.pl Repository:
Log of /FigKernelScripts/load_literature.pl
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
Thu Jun 9 05:51:06 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.1: +6 -27 lines
Tue Nov 2 14:45:31 2004 UTC (15 years ago) by overbeek
fix bug in subsys.cgi and add Literature to Global
