[Bio] / FigKernelScripts / load_kegg.pl Repository:
Log of /FigKernelScripts/load_kegg.pl
Thu Mar 11 19:30:00 2010 UTC (9 years, 11 months ago) by dejongh
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Fix KEGG location
Fri Oct 30 17:58:33 2009 UTC (10 years, 3 months ago) by dejongh
CVS Tags: rast_rel_2010_0118
Changes since 1.13: +3 -0 lines
ignore map 01100
Thu Mar 26 13:24:49 2009 UTC (10 years, 10 months ago) by dejongh
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.12: +5 -4 lines
Backwards compatibility fix for map names
Mon Mar 16 10:53:57 2009 UTC (10 years, 11 months ago) by dejongh
CVS Tags: rast_rel_2009_03_26
use FIG_Config::kegg
Mon Feb 23 16:35:49 2009 UTC (10 years, 11 months ago) by dejongh
Changes since 1.10: +3 -2 lines
Fix map name with backward compatibility
Thu Nov 13 21:56:09 2008 UTC (11 years, 3 months ago) by dejongh
CVS Tags: rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05
Changes since 1.9: +6 -5 lines
Use the KEGG mirror directory specified by FIG_Config::kegg_data
Tue Sep 25 19:54:59 2007 UTC (12 years, 4 months ago) by dejongh
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.8: +145 -145 lines
Tue May 15 21:13:29 2007 UTC (12 years, 9 months ago) by olson
Changes since 1.7: +162 -45 lines
Hope College modifications.
Wed Nov 2 21:43:17 2005 UTC (14 years, 3 months ago) by parrello
CVS Tags: caBIG-00-00-00
Fixed to allow for compounds with single-character names.
Wed Sep 28 22:22:39 2005 UTC (14 years, 4 months ago) by overbeek
CVS Tags: caBIG-dataload-0
Changes since 1.4: +9 -0 lines
fix to HOPSS.cgi
Thu Jun 9 05:51:06 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.3: +156 -234 lines
Wed Mar 16 21:48:45 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.2: +22 -22 lines
load_kegg should work now
Wed Jun 16 14:25:36 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.1: +16 -16 lines
New map support.
Mon Dec 1 20:46:40 2003 UTC (16 years, 2 months ago) by efrank
Makefile:
All the rest:
