[Bio] / FigKernelScripts / load_go.pl Repository:
Log of /FigKernelScripts/load_go.pl
Links to mgrast_dev_02212011: (view) (download) (as text) (annotate)
Thu Nov 30 23:04:16 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.1: +43 -19 lines
put in the fr2go stuff
Wed Nov 29 20:32:09 2006 UTC (13 years, 4 months ago) by mkubal
loads go_number_to_term table
