[Bio] / FigKernelScripts / load_go.pl Repository:
View of /FigKernelScripts/load_go.pl
Revision 1.2 - (download) (as text) (annotate)
Thu Nov 30 23:04:16 2006 UTC (13 years, 4 months ago) by overbeek
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Changes since 1.1: +43 -19 lines
put in the fr2go stuff
# Public License.
# -*- perl -*-
use strict;
use FIG;
my $fig = new FIG;
my $usage = "usage: load_go";
use Tracer;
my $dbf = $fig->db_handle;
$dbf->drop_table( tbl => "go_terms" );
$dbf->create_table( tbl  => "go_terms",
		    flds => "go_id char(10), go_desc varchar(200), go_type char(1), obsolete char(3)"
my $temp_dir = $FIG_Config::temp;
open(TMP,">$temp_dir/go.$$") || die "could not open temporary file";
if (open(GO,"<$FIG_Config::data/Ontologies/GO/GO.terms_ids_obs"))
    while (defined($_ = <GO>))
	if ($_ =~ /^GO:\d{7}\t/)
	    print TMP $_;
    close(GO);
close(TMP);
$dbf->load_table( tbl => "go_terms",
		  file => "$temp_dir/go.$$" );
unlink("$temp_dir/go.$$");
$dbf->create_index( idx  => "go_id_ix",
		    tbl  => "go_terms",
		    type => "btree",
		    flds => "go_id" );
$dbf->vacuum_it("go_terms");
$dbf->drop_table( tbl => "fr2go" );
$dbf->create_table( tbl  => "fr2go",
		    flds => "role varchar(200), go_id char(10)"
$dbf->load_table( tbl => "fr2go",
		  file => "$FIG_Config::data/Ontologies/GO/fr2go" );
$dbf->create_index( idx  => "fr2go_fr_ix",
		    tbl  => "fr2go",
		    type => "btree",
		    flds => "role" );
$dbf->create_index( idx  => "fr2go_go_ix",
		    tbl  => "fr2go",
		    type => "btree",
		    flds => "go_id" );
$dbf->vacuum_it("fr2go");
