[Bio] / FigKernelScripts / load_features.pl Repository:
View of /FigKernelScripts/load_features.pl
Revision 1.24 - (download) (as text) (annotate)
Wed May 7 16:08:22 2008 UTC (11 years, 7 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Changes since 1.23: +2 -2 lines
fix tmp file name.
# -*- perl -*-
# Public License.
use strict;
use FIG;
my $fig = new FIG;
use Tracer;
if ($ENV{'VERBOSE'}) { TSetup("3 FIG DBKernel","TEXT") }
Trace("Preparing to load features.") if T(2);
my ($mode, @genomes) = FIG::parse_genome_args(@ARGV);
my $temp_dir = "$FIG_Config::temp";
my $organisms_dir = "$FIG_Config::organisms";
my($genome,@types,$type,$id,$loc,@aliases,$aliases,$contig);
# usage: load_features [G1 G2 G3 ... ]
Open(\*REL, ">$temp_dir/tmpfeat$$");
Open(\*ALIAS, "| sort -T $temp_dir -u > $temp_dir/tmpalias$$");
Open(\*DELFIDS,"| sort -u > $temp_dir/tmpdel$$");
Open(\*REPFIDS,"| sort -u > $temp_dir/tmprel$$");
if ($mode eq 'all') {
    # Process any remaining deleted.features or replaced.features in Global
    if (open(GLOBDEL,"<$FIG_Config::global/deleted.features"))
	while (defined($_ = <GLOBDEL>) && ($_ =~ /^fig\|(\d+\.\d+)/))
	    print DELFIDS "$1\t$_";
    close(GLOBDEL);
    if (open(GLOBREP,"<$FIG_Config::global/replaced.features"))
	while (defined($_ = <GLOBREP>) && ($_ =~ /^fig\|(\d+\.\d+)/))
	    print REPFIDS "$1\t$_";
    close(GLOBREP);
    # Here we extract external aliases from the peg.synonyms table, when they can be inferred
    # accurately.
	Trace("Extracting external aliases from the peg.synonyms table.") if T(2);
    Open(\*SYN, "<$FIG_Config::global/peg.synonyms");
    while (defined($_ = <SYN>))
		chop;
		my($x,$y) = split(/\t/,$_);
		my @ids = map { $_ =~ /^([^,]+),(\d+)/; [$1,$2] } ($x,split(/;/,$y));
		my @fig = ();
		my(@nonfig) = ();
		foreach $_ (@ids)
			if ($_->[0] =~ /^fig\|/)
				push(@fig,$_);
			else
				push(@nonfig,$_);
		foreach $x (@fig)
			my($peg,$peg_ln) = @$x;
			my $genome = &FIG::genome_of($peg);
			foreach $_ (@nonfig)
				if ((@fig == 1) || ($peg_ln == $_->[1]))
					print ALIAS "$peg\t$_->[0]\t$genome\n";
					Trace("Alias record $peg, $_->[0] for $genome.") if T(4);
    close(SYN);
foreach $genome (@genomes)
	Trace("Processing $genome.") if T(3);
    opendir(FEAT,"$organisms_dir/$genome/Features")
		|| die "could not open $genome/Features";
    @types = grep { $_ =~ /^[a-zA-Z]+$/ } readdir(FEAT);
    closedir(FEAT);
    foreach $type (@types)
	if ((-s "$organisms_dir/$genome/Features/$type/deleted.features") &&
	    open(TMP,"<$organisms_dir/$genome/Features/$type/deleted.features"))
	    while (defined($_ = <TMP>) && ($_ =~ /^fig\|(\d+\.\d+)/))
	    close(TMP);
	if ((-s "$organisms_dir/$genome/Features/$type/replaced.features") &&
	    open(TMP,"<$organisms_dir/$genome/Features/$type/replaced.features"))
	    close(TMP);
	if ((-s "$organisms_dir/$genome/Features/$type/tbl") &&
	    open(TBL,"<$organisms_dir/$genome/Features/$type/tbl"))
	    Trace("Loading $genome/Features/$type/tbl") if T(4);
	    my @tbl = <TBL>;
	    close(TBL);
	    my %seen;
	    while ($_ = pop @tbl)
		chop;
		($id,$loc,@aliases) = split(/\t/,$_);
		if ($id && (! $seen{$id}))
		    $seen{$id} = 1;
		    my($minloc,$maxloc);
		    if ($loc)
			$loc =~ s/\s+$//;
			($contig,$minloc,$maxloc) = $fig->boundaries_of($loc);
			if ($minloc && $maxloc)
			    ($minloc < $maxloc) || (($minloc,$maxloc) = ($maxloc,$minloc));
		    if (! $contig)
			$loc = $contig = $minloc = $maxloc = "";
		    if (@aliases > 0)
			$aliases = join(",",grep(/\S/,@aliases));
			my $alias;
			foreach $alias (@aliases)
			    if ($alias =~ /^([NXYZA]P_|gi\||sp\|\tr\||kegg\||uni\|)/)
				print ALIAS "$id\t$alias\t$genome\tOVERRIDE\n";
				Trace("$id override alias $alias for $genome") if T(4);
		    else
			$aliases = "";
		    $minloc = (! $minloc) ? 0 : $minloc;
		    $maxloc = (! $maxloc) ? 0 : $maxloc;
		    if ((length($loc) < 5000) && (length($contig) < 96) && (length($id) < 32) && ($id =~ /(\d+)$/))
			print REL "$id\t$1\t$type\t$genome\t$loc\t$contig\t$minloc\t$maxloc\t$aliases\n";
close(REPFIDS);
close(DELFIDS);
close(REL);
close(ALIAS);
Open(\*ALIASIN, "<$temp_dir/tmpalias$$");
Open(\*ALIASOUT, ">$temp_dir/tmpalias$$.1");
Trace("Parsing alias file.") if T(2);
$_ = <ALIASIN>;
while ($_ && ($_ =~ /^(\S+)/))
    my @aliases = ();
    my $curr = $1;
    while ($_ && ($_ =~ /^(\S+)\t(\S+)(\t(\S+))?/) && ($1 eq $curr))
		push(@aliases,[$2,$3 ? 1 : 0]);
		$_ = <ALIASIN>;
    my $x;
    my $genome = &FIG::genome_of($curr);
    foreach $x (@aliases)
	if ($x->[1])
	    print ALIASOUT "$curr\t$x->[0]\t$genome\n";
	else
	    my $i;
	    for ($i=0; ($i < @aliases) && ((! $aliases[$i]->[1]) || (! &same_class($x->[0],$aliases[$i]->[0]))); $i++) {}
	    if ($i == @aliases)
close(ALIASIN);
close(ALIASOUT);
unlink("$temp_dir/tmpalias$$");
$fig->reload_table($mode, 'deleted_fids',"genome varchar(16), fid varchar(32)",
		                         { deleted_fids_fid_ix => 'fid', deleted_fids_genome_ix => 'genome' },
		                         "$temp_dir/tmpdel$$",\@genomes);
unlink("$temp_dir/tmpdel$$");
$fig->reload_table($mode, 'replaced_fids',"genome varchar(16), from_fid varchar(32), to_fid varchar(32)",
		                         { replaced_fids_from_ix => 'from_fid',
                                           replaced_fids_to_ix => 'to_fid',
                                           replaced_fids_genome_ix => 'genome'
		                         "$temp_dir/tmprel$$",\@genomes);
unlink("$temp_dir/tmprel$$");
$fig->reload_table($mode, 'features',
				   "id varchar(32), idN INTEGER, type varchar(16),genome varchar(16),"  .
			            "location TEXT,"  .
			            "contig varchar(96), minloc INTEGER, maxloc INTEGER,"  .
			            "aliases TEXT",
					{ features_id_ix => "id", features_org_ix => "genome",
					  features_type_ix => "type", features_beg_ix => "genome, contig, minloc" },
					"$temp_dir/tmpfeat$$", \@genomes);
unlink("$temp_dir/tmpfeat$$");
$fig->reload_table($mode, 'ext_alias',
					"id varchar(32), alias varchar(32), genome varchar(16)",
					{ ext_alias_alias_ix => "alias", ext_alias_genome_ix => "genome",
					  ext_alias_ix_id => "id" },
					"$temp_dir/tmpalias$$.1", \@genomes );
unlink("$temp_dir/tmpalias$$.1");
Trace("Features loaded.") if T(2);
sub same_class {
    my($x,$y) = @_;
    my $class1 = &classA($x);
    my $class2 = &classA($y);
    return ($class1 && ($class1 eq $class2));
sub classA {
    my($alias) = @_;
    if ($alias =~ /^([^\|]+)\|/)
		return $1;
    elsif ($alias =~ /^[NXYZA]P_[0-9\.]+$/)
		return "refseq";
    else
		return "";
