[Bio] / FigKernelScripts / load_features.pl Repository:
Log of /FigKernelScripts/load_features.pl
Links to caBIG-13Feb06-00: (view) (download) (as text) (annotate)
Sun Jan 15 20:21:44 2006 UTC (14 years ago) by overbeek
Changes since 1.21: +7 -7 lines
Diff to previous 1.21 , to selected 1.15
fixes to deletion of features
Fri Jan 13 20:22:40 2006 UTC (14 years ago) by overbeek
Changes since 1.20: +62 -2 lines
Diff to previous 1.20 , to selected 1.15
fixes to deleted_features, replace_features_with, etc
Mon Dec 5 18:56:37 2005 UTC (14 years, 1 month ago) by olson
Changes since 1.19: +17 -0 lines
Diff to previous 1.19 , to selected 1.15
Thu Sep 8 21:28:14 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.18: +66 -81 lines
Diff to previous 1.18 , to selected 1.15
fixes to load_features for duplicate tbl entries
Thu Jun 9 05:51:06 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.17: +137 -201 lines
Diff to previous 1.17 , to selected 1.15
Tue Mar 29 18:42:26 2005 UTC (14 years, 9 months ago) by overbeek
Diff to previous 1.16 , to selected 1.15
broaden set of acceptable aliases as dbxrefs
Sat Feb 5 16:05:29 2005 UTC (14 years, 11 months ago) by overbeek
have sort in load_features use FIG/Tmp for sort files
Revision 1.15 - (view) (download) (as text) (annotate) - [selected]
Mon Jan 17 17:20:52 2005 UTC (15 years ago) by olson
Remove debugging prints.
Tue Jan 4 22:28:29 2005 UTC (15 years ago) by overbeek
Changes since 1.13: +64 -3 lines
Diff to previous 1.13 , to selected 1.15
modifications to load_features to generate aliases
Sat Jan 1 14:33:50 2005 UTC (15 years ago) by overbeek
Changes since 1.12: +11 -6 lines
Diff to previous 1.12 , to selected 1.15
add aliases from mapped proteins correctly
Fri Aug 20 17:37:58 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.11: +20 -0 lines
Diff to previous 1.11 , to selected 1.15
update feature alterations
Mon Aug 16 22:10:55 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.10: +5 -5 lines
Diff to previous 1.10 , to selected 1.15
straighten out FIG.pm
Thu May 20 12:26:47 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.9: +39 -1 lines
Diff to previous 1.9 , to selected 1.15
make aliases include external aliases
Wed Apr 28 00:06:34 2004 UTC (15 years, 8 months ago) by overbeek
Diff to previous 1.8 , to selected 1.15
gi2fig
Fri Mar 5 22:17:16 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.7: +32 -0 lines
Diff to previous 1.7 , to selected 1.15
support gi and NP numbers for access to fig IDs
Wed Dec 31 23:47:18 2003 UTC (16 years ago) by overbeek
Changes since 1.6: +2 -2 lines
Diff to previous 1.6 , to selected 1.15
get rid of implied index on features
Mon Dec 29 02:22:37 2003 UTC (16 years ago) by overbeek
Changes since 1.5: +6 -2 lines
Diff to previous 1.5 , to selected 1.15
numerous performance issues
Fri Dec 26 13:01:58 2003 UTC (16 years ago) by overbeek
Diff to previous 1.4 , to selected 1.15
fix screwup on load_features
Fri Dec 26 04:25:44 2003 UTC (16 years ago) by overbeek
Changes since 1.3: +17 -14 lines
Diff to previous 1.3 , to selected 1.15
defer indexes until after complete load
Tue Dec 23 19:43:42 2003 UTC (16 years ago) by overbeek
Changes since 1.2: +4 -1 lines
Diff to previous 1.2 , to selected 1.15
check for data items too large in load_features
Sat Dec 20 15:19:21 2003 UTC (16 years, 1 month ago) by overbeek
Diff to previous 1.1 , to selected 1.15
for incremental additions to the DB, delete old versions of things
Mon Dec 1 20:46:40 2003 UTC (16 years, 1 month ago) by efrank
Diff to selected 1.15
Makefile:
All the rest:
