[Bio] / FigKernelScripts / load_coupling.pl Repository:
Log of /FigKernelScripts/load_coupling.pl
Tue Feb 21 14:37:25 2006 UTC (13 years, 11 months ago) by olson
Changes since 1.8: +0 -3 lines
Remove debugging.
Sun Feb 19 04:15:44 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.7: +117 -25 lines
minor fixes to auto_assign
Mon Dec 5 18:56:37 2005 UTC (14 years, 1 month ago) by olson
Wed Aug 17 19:32:24 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.5: +13 -4 lines
Add table size estimation code for supporting MyISAM.
Wed Jun 22 21:23:43 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.4: +30 -34 lines
Converted to use the reload_table method. This method determines whether or not to create the indexes before or after loading.
Mon Jun 20 20:09:58 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.3: +3 -3 lines
Load from FIG/Data/CouplingData instead of FIG/CouplingData
Wed Jun 1 01:18:50 2005 UTC (14 years, 7 months ago) by overbeek
CVS Tags: Root-bobdev_news
Changes since 1.2: +4 -6 lines
Mon May 30 21:57:23 2005 UTC (14 years, 7 months ago) by overbeek
fixes to load_coupling
Sun May 15 11:49:37 2005 UTC (14 years, 8 months ago) by overbeek
Diff to selected 1.4
minor fixes in computing functional coupling
