[Bio] / FigKernelScripts / load_close.pl Repository:
Log of /FigKernelScripts/load_close.pl
Sun Mar 25 14:21:41 2007 UTC (12 years, 7 months ago) by overbeek
tighten length constraints for figfam matching
Thu Feb 16 23:03:37 2006 UTC (13 years, 8 months ago) by olson
Changes since 1.7: +63 -12 lines
If we are loading unmapped files (as generated by make_close -no-map  and make_sim_tab -no-map),
do the mapping before loading into db.
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
Fri Sep 9 17:21:51 2005 UTC (14 years, 2 months ago) by olson
Fixes for coupling scripts.
Wed Aug 17 13:35:44 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.4: +12 -3 lines
more fixes
Wed Aug 17 13:29:22 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.3: +11 -1 lines
postgres fix for sims/closetab stuff
Sun May 29 02:15:42 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.2: +4 -2 lines
Updated tools for functional coupling computation. Replace string
pges with (genome, peg) pairs.
Sat May 7 21:33:30 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.1: +5 -1 lines
take some of the hardwired directories out of BigFC
Sat May 7 20:57:47 2005 UTC (14 years, 6 months ago) by overbeek
add routines for BigFC
