[Bio] / FigKernelScripts / load_attributes.pl Repository:
Log of /FigKernelScripts/load_attributes.pl
Thu Dec 6 14:00:37 2007 UTC (12 years, 4 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_release_2008_09_29
Changes since 1.44: +8 -8 lines
Diff to previous 1.44
Tue Dec 5 19:09:22 2006 UTC (13 years, 4 months ago) by olson
Changes since 1.43: +24 -9 lines
Diff to previous 1.43
preindex tables if configured to do so.
Fri Aug 25 04:08:43 2006 UTC (13 years, 7 months ago) by redwards
Changes since 1.42: +11 -1 lines
Diff to previous 1.42
finally, I know what the ev code problem is. There are too many of them because we keep creating them and saving the old ones.
Thu Mar 23 04:51:55 2006 UTC (14 years ago) by overbeek
Changes since 1.41: +1 -1 lines
Diff to previous 1.41
RAE: Yummy attributes
Sun Jan 15 21:29:41 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.40: +7 -5 lines
Diff to previous 1.40
Converted to use "StandardSetup".
Fri Jan 6 05:09:29 2006 UTC (14 years, 3 months ago) by parrello
Changes since 1.39: +1 -0 lines
Diff to previous 1.39
Fixed to keep a backup of any attribute files overwritten by a clean copy.
Fri Jan 6 00:41:06 2006 UTC (14 years, 3 months ago) by parrello
Changes since 1.38: +12 -7 lines
Diff to previous 1.38
Fixed the processing of feature attributes.
Thu Jan 5 23:58:54 2006 UTC (14 years, 3 months ago) by parrello
Changes since 1.37: +8 -2 lines
Diff to previous 1.37
Added more tracing.
Thu Jan 5 23:48:13 2006 UTC (14 years, 3 months ago) by parrello
Changes since 1.36: +32 -14 lines
Diff to previous 1.36
Fixed some more bugs.
Thu Jan 5 22:20:16 2006 UTC (14 years, 3 months ago) by parrello
Changes since 1.35: +2 -2 lines
Diff to previous 1.35
Fixed an error in the directory handling for feature attributes.
Thu Jan 5 21:34:40 2006 UTC (14 years, 3 months ago) by parrello
Changes since 1.34: +10 -5 lines
Diff to previous 1.34
Thu Jan 5 21:31:24 2006 UTC (14 years, 3 months ago) by parrello
Changes since 1.33: +310 -205 lines
Diff to previous 1.33
Rewrote to automatically clean bad keys and errors from attribute files.
Wed Jan 4 20:12:31 2006 UTC (14 years, 3 months ago) by parrello
Changes since 1.32: +5 -4 lines
Diff to previous 1.32
Added a debug switch to figure out the key problem..
Wed Jan 4 16:28:16 2006 UTC (14 years, 3 months ago) by overbeek
Changes since 1.31: +4 -4 lines
Diff to previous 1.31
RAE: ignore files ending ~
Thu Dec 15 20:58:35 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.30: +3 -2 lines
Diff to previous 1.30
Potential fix for load_attributes
Sat Dec 10 18:08:17 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.29: +2 -2 lines
Diff to previous 1.29
RAE: Changed attribute key to tag throughout
Changes since 1.28: +17 -0 lines
Diff to previous 1.28
Thu Nov 24 00:02:30 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.27: +5 -4 lines
Diff to previous 1.27
ignoring keys without values
Wed Nov 23 20:34:59 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.26: +80 -14 lines
Diff to previous 1.26
major changes to attributes and protein families. There are changes to several modules to deal with new attributes database, and simultaneous updates to protein families
Wed Sep 21 20:56:20 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.25: +2 -6 lines
Diff to previous 1.25
correcting \r error
Mon Aug 1 22:02:22 2005 UTC (14 years, 8 months ago) by overbeek
Diff to previous 1.24
update evidence code writeup
Thu Jul 28 22:06:11 2005 UTC (14 years, 8 months ago) by overbeek
Diff to previous 1.23
removing trace in load_attributes by Rob
Wed Jul 27 21:16:42 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.22: +2 -2 lines
Diff to previous 1.22
fixng links
Fri Jul 22 22:27:48 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.21: +1 -0 lines
Diff to previous 1.21
updating load_attributes for better errors
Fri Jul 22 22:23:50 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.20: +1 -0 lines
Diff to previous 1.20
Tue Jul 19 06:12:44 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.19: +4 -3 lines
Diff to previous 1.19
Final touches to Attributes code for today
Tue Jul 19 04:54:21 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.18: +2 -0 lines
Diff to previous 1.18
Updating attributes code in seed
Mon Jul 18 03:12:11 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.17: +43 -5 lines
Diff to previous 1.17
Sun Jul 17 17:48:12 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.16: +144 -195 lines
Diff to previous 1.16
new load_attributes, basically rewritten but does the same thing
Fri Jul 15 03:23:54 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.15: +19 -0 lines
updating protein_info.cgi
Sat Jul 9 14:01:45 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.14: +8 -8 lines
fixes to load_attributes
Thu Jun 9 05:51:06 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.13: +118 -109 lines
Wed Apr 13 00:03:52 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.12: +1 -0 lines
fixed load_attributes. Hopefully
Tue Apr 12 22:58:32 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.11: +2 -3 lines
debugging load_attributes
Tue Apr 12 22:47:23 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.10: +8 -8 lines
debugging load_attrubutes
Tue Apr 12 21:46:00 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.9: +9 -2 lines
add error check to load_attributes
Tue Mar 22 17:02:48 2005 UTC (15 years ago) by redwards
Changes since 1.8: +51 -5 lines
minor changes to marine seed entry and added a new background
Tue Mar 22 03:13:30 2005 UTC (15 years ago) by redwards
Changes since 1.7: +27 -14 lines
adding conflict to complete_genomes.pl
Sun Mar 13 17:51:28 2005 UTC (15 years ago) by redwards
Changes since 1.6: +1 -0 lines
changes to load_attributes to fake url column and css sheets
Fri Mar 11 03:04:32 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.5: +6 -3 lines
Making tag/value pairs work
Fri Mar 4 22:37:06 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.4: +12 -1 lines
Added color by organism attributes to subsystems page
Fri Mar 4 06:22:10 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.3: +85 -39 lines
Big updates to FIG.pm for the addition of methods to properly handle attributes. Also modified genome_statistics to take advantage of these new methods. load_attributes will load genomes and other attributes but doesn't not yet use the new methods (but should), and Attributes.html is some docs.
Sun Feb 27 01:39:55 2005 UTC (15 years, 1 month ago) by overbeek
Changes since 1.2: +60 -13 lines
major changes in notion of function and load_attributes
Fri Sep 17 18:52:59 2004 UTC (15 years, 6 months ago) by overbeek
load attributes fix
Mon Sep 13 02:12:21 2004 UTC (15 years, 6 months ago) by overbeek
add attributes as key-value pairs attached to fids
