[Bio] / FigKernelScripts / install_new_coupling_data.pl Repository:
Log of /FigKernelScripts/install_new_coupling_data.pl
Thu Oct 4 19:27:00 2007 UTC (12 years, 1 month ago) by olson
Changes since 1.2: +20 -6 lines
add option to install from a jobdir
Thu Sep 6 21:55:10 2007 UTC (12 years, 2 months ago) by olson
Changes since 1.1: +23 -60 lines
changes to support rast import
Thu Feb 16 17:35:26 2006 UTC (13 years, 8 months ago) by olson
New script.
