[Bio] / FigKernelScripts / install-data.pl Repository:
Log of /FigKernelScripts/install-data.pl
Thu Nov 29 23:08:26 2007 UTC (11 years, 11 months ago) by olson
fix to dvd data installer
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
Tue Oct 19 19:02:00 2004 UTC (15 years ago) by olson
Changes since 1.5: +285 -14 lines
Fixed up installer.
Thu Oct 14 15:11:09 2004 UTC (15 years, 1 month ago) by olson
new installer stuff
Thu Oct 14 15:10:44 2004 UTC (15 years, 1 month ago) by olson
Changes since 1.3: +11 -3 lines
new installer stuff
Thu Oct 14 15:09:26 2004 UTC (15 years, 1 month ago) by olson
new installer stuff
Thu Oct 14 15:08:00 2004 UTC (15 years, 1 month ago) by olson
new installer stuff
Thu Oct 14 15:05:27 2004 UTC (15 years, 1 month ago) by olson
new installer stuff
