[Bio] / FigKernelScripts / insert_prot_into_tree.pl Repository:
Log of /FigKernelScripts/insert_prot_into_tree.pl
Wed Jan 31 21:30:36 2007 UTC (13 years, 2 months ago) by golsen
Continuing the update of tree packages and programs
Mon Jan 29 23:13:27 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.12: +1 -0 lines
bring tree insertion up to date
Mon Jan 29 22:43:52 2007 UTC (13 years, 2 months ago) by golsen
Changes since 1.11: +25 -51 lines
Work on moving sequence insertion into modules.
Mon Jan 29 18:59:08 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.10: +4 -1 lines
debugged version of bring_tree_up_to_ali
Fri Jan 12 18:44:25 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.9: +0 -2 lines
Remove use File::msktemp. Interfers with the creation of temp files
Thu Jan 11 19:59:54 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.8: +2 -4 lines
delete temp directories in phylogeny tools
Thu Jan 11 00:01:36 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.7: +3 -2 lines
fixed anoter typo error
Wed Jan 10 16:50:00 2007 UTC (13 years, 2 months ago) by overbeek
Making temporary files unique
Mon Jan 8 19:47:28 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.5: +13 -4 lines
add tree_neighbors and latest phylogeny stuff
Sat Jan 6 17:39:41 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.4: +53 -20 lines
make sure tree insertion code is all committed
Fri Jan 5 02:13:04 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.3: +17 -12 lines
add make_neigh_joining_tree and make_proml_tree
Thu Dec 21 04:01:23 2006 UTC (13 years, 3 months ago) by overbeek
check sz of rep tree to 40 in insert_prot_into_tree
Wed Dec 20 15:30:19 2006 UTC (13 years, 3 months ago) by overbeek
add bring_tree_up_to_ali
Tue Dec 19 21:07:16 2006 UTC (13 years, 3 months ago) by overbeek
add insert_prot_into_tree, a new way to insert proteins into a tree
