[Bio] / FigKernelScripts / insert_into_a_tree.pl Repository:
Log of /FigKernelScripts/insert_into_a_tree.pl
Mon Jan 8 19:47:28 2007 UTC (13 years, 4 months ago) by overbeek
Changes since 1.4: +8 -6 lines
add tree_neighbors and latest phylogeny stuff
Sat Jan 6 17:39:41 2007 UTC (13 years, 4 months ago) by overbeek
Changes since 1.3: +9 -11 lines
make sure tree insertion code is all committed
Fri Dec 15 00:53:03 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.2: +0 -25 lines
remove crud from start of insert_into_tree.pl
Fri Dec 15 00:46:54 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.1: +21 -2 lines
add checkpoints to insertion into trees
Fri Dec 15 00:09:52 2006 UTC (13 years, 5 months ago) by overbeek
add ability to insert sequences into a tree
