[Bio] / FigKernelScripts / initialize_alignments_for_subsystems.pl Repository:
Log of /FigKernelScripts/initialize_alignments_for_subsystems.pl
Thu Jan 5 01:09:56 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.1: +18 -0 lines
fixes to extract_genomes, salvage_subsystem_rows and initialize_alignments_for_subsystems
Wed Jan 4 14:46:24 2006 UTC (13 years, 11 months ago) by overbeek
add initialize_alignments_for_subsystems
