[Bio] / FigKernelScripts / index_subsystems.pl Repository:
View of /FigKernelScripts/index_subsystems.pl
Revision 1.15 - (download) (as text) (annotate)
Tue Jun 14 21:56:22 2011 UTC (8 years, 5 months ago) by olson
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, rast_rel_2014_0912, myrast_rel40, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2014_0729, mgrast_release_3_1_2, mgrast_release_3_1_1, rast_rel_2011_0928, mgrast_dev_10262011, HEAD
Changes since 1.14: +9 -0 lines
add nonaux role index
# -*- perl -*-
# Public License.
# usage: index_subsystems [sub1 sub2 ...]
# if there are arguments, then the database is NOT reinitialized, and only the
# designated new set of subsystms is indexed.
use Subsystem;
use FIG;
my $fig = new FIG;
use Tracer;
my @to_process = ();
my $dbf = $fig->{_dbf};
if (@ARGV == 0)
    Trace("Recreating subsystem index table.") if T(2);
    $dbf->drop_table( tbl => "subsystem_index" );
    $dbf->create_table( tbl  => "subsystem_index",
			flds => <<EOFLD);
    protein varchar(32),
    subsystem varchar(255),
    role varchar(255),
    variant varchar(32)
EOFLD
    $dbf->drop_table( tbl => "subsystem_genome_variant" );
    $dbf->create_table( tbl  => "subsystem_genome_variant",
			flds => <<EOFLD);
    genome varchar(255),
    variant varchar(32)
EOFLD
    $dbf->drop_table( tbl => "subsystem_genome_role" );
    $dbf->create_table( tbl  => "subsystem_genome_role",
			flds => <<EOFLD);
    role varchar(255)
EOFLD
    $dbf->drop_table( tbl => "subsystem_nonaux_role" );
    $dbf->create_table( tbl  => "subsystem_nonaux_role",
			flds => <<EOFLD);
    role varchar(255)
EOFLD
    $dbf->drop_table( tbl => "aux_roles" );
    $dbf->create_table( tbl => "aux_roles", flds => "subsystem varchar(255),role varchar(255)" );
    $dbf->drop_table(tbl => "subsystem_metadata");
    $dbf->create_table(tbl => "subsystem_metadata",
		      flds => qq(subsystem	varchar(255),
				 classification	text,
				 class_1	varchar(255),
				 class_2	varchar(255),
				 curator	varchar(255),
				 creation_date	integer,
				 last_update	integer,
				 version	integer,
				 exchangable	integer
# Determine which subsystems to load.
my @subsystems;
my $skip_delete;
if (@ARGV == 0)
    # Use the class method to force a directory scan.
    @subsystems = &FIG::all_subsystems();
    $skip_delete = 1;
else
    @subsystems = @ARGV;
    $skip_delete = 0;
Trace("Iterating through subsystems.") if T(2);
for my $subsystem (@subsystems)
    Trace("Processing subsystem $subsystem.") if T(3);
    #  Don't use get_subsystem because that caches them all in memory.
    #    my $sub = $fig->get_subsystem($subsystem);
    my $sub = Subsystem->new($subsystem, $fig);
    if (!$sub)
	Trace("Could not find subsystem for $subsystem") if T(1);
	next;
    $sub->db_sync($skip_delete);
if (@ARGV == 0)
    Trace("Indexing subsystem table.") if T(2);
    $dbf->create_index( idx  => "subsystems_protein_ix",
		       type => "btree",
		       flds => "protein");
    $dbf->create_index( idx  => "subsystems_role_ix",
		       type => "btree",
		       flds => "role");
    $dbf->create_index( idx  => "subsystems_by_subsystem_ix",
		       type => "btree",
		       flds => "subsystem");
    $dbf->create_index( idx => "aux_roles_ids",
		       tbl => "aux_roles",
		       type => "btree",
		       flds => "subsystem,role");
    $dbf->create_index( idx => "subsystem_nonaux_role_ix",
    $dbf->create_index(idx => "subsystem_metadata_ix",
    $dbf->create_index(idx => "subsystem_genome_variant_idx",
    $dbf->create_index(idx => "subsystem_genome_role_idx",
    $dbf->vacuum_it("subsystem_index");
    $dbf->vacuum_it("subsystem_metadata");
    $dbf->vacuum_it("aux_roles");
undef $fig;
Trace("Subsystems indexed.");
