[Bio] / FigKernelScripts / index_sprout.pl Repository:
View of /FigKernelScripts/index_sprout.pl
Revision 1.12 - (download) (as text) (annotate)
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Changes since 1.11: +17 -0 lines
# Public License.
# Sprout indexer.
# usage: index_sprout
use FIG;
use FIG_Config;
use Sprout;
use SproutFIG;
use Data::Dumper;
use DB_File;
use Fcntl;
use Tracer;
use strict;
TSetup("2 Sprout", "ERROR");
my $sproutData = "$FIG_Config::sproutData";
my $sfig  = SproutFIG->new($FIG_Config::sproutDB, $FIG_Config::sproutData);
my $indexDir = "$sproutData/Indexes";
&FIG::verify_dir($indexDir);
if (! -d $sproutData)
    die "Sprout data directory not found\n";
# Create indexes.
# We only index a subset of the data files.
my @index_files = create_index_files();
my $glimpse_input;
for my $f (@index_files)
    if (-f $f)
	$glimpse_input .= "$f\n";
    else
	warn "Cannot find sprout data file to index: $f\n";
# Clear out old indexes.
if (opendir(D, "$indexDir"))
    foreach (readdir(D))
	if (/\.glimpse/)
	    my $p = "$sproutData/Indexes/$_";
	    print "Remove $p\n";
	    unlink $p or die "Cannot remove $p: $!\n";
    closedir(D);
open(P, "| $FIG_Config::ext_bin/glimpseindex -b -E -n -z -H $sproutData/Indexes -F ");
print P $glimpse_input;
close(P);
opendir(D, "$sproutData/Indexes");
for $_ (readdir(D))
    if (/^\.glimpse/)
	chmod 0666, "$sproutData/Indexes/$_";
sub create_index_files
    my @files;
    push(@files, create_property_index());
    push(@files, create_feature_index());
    push(@files, create_alias_index());
    push(@files, create_annotation_index());
    return @files;
sub create_feature_index
    # Create an index of the feature stuff - genus/species, tax, etc.
    Trace("Creating feature index\n");
    if (!open(F, "<$sproutData/Genome.dtx"))
	warn "Cannot open Feature table: $!\n";
	return;
    my %genome;
    while (<F>)
	chomp;
	my ($genome, undef, $genus, $species, $strain, $tax) = split(/\t/);
	$tax =~ s/;//g;
	push(@{$genome{$genome}}, $genus, $species, $strain, $tax);
    close(F);
    # Read the ComesFrom table too.
    if (!open(F, "<$sproutData/ComesFrom.dtx"))
	warn "Cannot open ComesFrom table: $!\n";
	return;
    while (<F>)
	chomp;
	my ($genome, $origin) = split(/\t/);
	push(@{$genome{$genome}}, $origin);
    close(F);
    # Read the features table, and write the index for it.
    my $index_file = "$indexDir/feature";
    if (!open(IDX, ">$index_file"))
	warn "cannot open $index_file for writing: $!\n";
	return;
    if (!open(F, "<$sproutData/Feature.dtx"))
	return;
    while (<F>)
	chomp;
	if (/^(fig\|(\d+\.\d+)[^\t]+)\t/)
	    my $peg = $1;
	    my $gid = $2;
	    my $info = $genome{$gid};
	    if (ref($info))
		print IDX "$peg\t", join(" ", @{$genome{$gid}}), "\n";
	    else
		Trace("No info for $peg gid=$gid") if T(3);
    close(F);
    close(IDX);
    return $index_file;
sub create_property_index
    Trace("Creating property index.");
    # Create a table
    #   peg propname [propname...]
    # where each property has a nonzero value.
    # We define some aliases here for the matches
    # that people might make.
    my %aliases = (
		   'virulence-associated' =>  ['virulent', 'virulence'],
    # Read the property values. Maintain a list of wanted-properties that
    # have nonzero values.
    if (!open(F, "<$sproutData/Property.dtx"))
	warn "Cannot open property table: $!\n";
	return;
    my %wanted_properties;
    my %values;
    while (<F>)
	chomp;
	my($id, $name, $value) = split(/\t/);
	if ($value ne "0")
	    $wanted_properties{$id} = $name;
	    $aliases{$name} = [] unless $aliases{$name};
	    $values{$id} = $value;
	else
	    print "Skipping $id\n";
    close(F);
    my $index_file = "$indexDir/peg_property";
	warn "Cannot open $indexDir/peg_property for writing: $!\n";
	return;
    if (!open(F, "<$sproutData/HasProperty.dtx"))
	warn "Cannot open HasProperty table: $!\n";
	return;
    while (<F>)
	chomp;
	my($peg, $id) = split(/\t/);
	if (my $name = $wanted_properties{$id})
	    print IDX "$peg\t$name ", join(" ", @{$aliases{$name}}, $values{$id}), "\n";
	else
	    print "Didn't find wanted props for $id\n";
    close(F);
    close(IDX);
    return $index_file;
sub create_annotation_index
    Trace("Creating annotation index.");
    # Create the annotation index table.
    # It contains a line for each annotation, of the form
    # peg_id unique words in annotation
    # We create this by relying on the structure of the keys in the Annotation
    # table being of the form figid:timestamp, so we can just drop the timestamp.
    my $index_file = "$indexDir/annotation";
    if (!open(F, "<$sproutData/Annotation.dtx"))
	warn "Cannot open Annotation table: $!\n";
	return;
	warn "Cannot open $index_file for writing: $!\n";
	return;
    while (<F>)
	chomp;
	my ($aid, $ts, $anno) = split(/\t/);
	if ($aid =~ /^(fig\|.*):\d+/)
	    my $peg = $1;
	    my %awords;
	    $anno =~ s/\\./ /g;
	    map { $awords{$_}++ } $anno =~ /\S+/g;
	    my @extra;
	    for my $aw (keys(%awords))
		if ($aw =~ /(\d+\.\d+\.\d+\.[\d|-]+)/)
		    push(@extra, $1);
	    print IDX "$peg\t", join(" ", keys(%awords), @extra), "\n";
    close(F);
    close(IDX);
    return $index_file;
sub create_alias_index
    Trace("Creating alias index.");
    # Create the alias index files.
    # Read the featurealias table.
    my(@index_files);
    my %alias_to_id;
#    my $dbm_file = "$FIG_Config::temp/index_sprout.$$.db";
#    my $tied = tie %alias_to_id, 'DB_File', $dbm_file,  O_CREAT | O_RDWR, 0666, $DB_HASH;
#    $tied or die "Cannot create DB_File $tied: $!";
    if (!open(F, "<$sproutData/FeatureAlias.dtx"))
	warn "Cannot open FeatureAlias table: $!\n";
	return;
    # Read FeatureAlias table. This table maps
    # each feature ID to its aliases:
    #	fig|217.1.peg.1040      gi|729512
    #	fig|217.1.peg.1040      sp|Q07910
    #	fig|217.1.peg.1040      uni|Q07910
    # In order to save memory overhead, we scan sequentially, collecting the set
    # of aliases for each peg and writing the external_alias index file.
    # We also collect the alias->peg mapping in the DB_File hash.
    Trace("Read FeatureAlias " . time . "");
    my $index_file = "$indexDir/external_alias";
    push(@index_files, $index_file);
	return;
    my $cur;
    my @aliases;
    while (<F>)
	chomp;
	my($id, $alias) = split(/\t/);
	if ($cur and $id ne $cur)
	    print IDX join("\t", $cur, @aliases), "\n";
	    @aliases = ();
	    $cur = $id;
	elsif (not $cur)
	    $cur = $id;
	# For aliases of the form key|value, add "value" to the list.
	push(@aliases, $alias);
	if ($alias =~ /^[^|]+\|(.*)$/)
	    push(@aliases, $1);
	$alias_to_id{$alias} .= "$id ";
	Trace("$.") if $. % 10000 == 0;
    close(F);
    close(IDX);
    # Now handle the external alias tables.
    if (!open(F, "<$sproutData/ExternalAliasOrg.dtx"))
	warn "Cannot open table ExternalAliasOrg: $!\n";
	return;
    Trace("Index for ExternalAliasOrg " . time);
    my %peg_words;
    while (<F>)
	chomp;
	my($alias, $org) = split(/\t/);
	# Fix a bug in some org names.
	$org =~ s/^\d+://;
	for my $peg (split(/ /, $alias_to_id{$alias}))
	    if ($peg ne "")
		push(@{$peg_words{$peg}}, $org);
    close(F);
    my $index_file = "$indexDir/external_alias_org";
	return;
    Trace("Write index " . time);
    for my $peg (keys(%peg_words))
	print IDX "$peg\t", join(" ", @{$peg_words{$peg}}), "\n";
    close(IDX);
    # And the functions.
    if (!open(F, "<$sproutData/ExternalAliasFunc.dtx"))
	warn "Cannot open table ExternalAliasFunc: $!\n";
	return;
    Trace("Index for ExternalAliasFunc " . time);
    my %peg_words;
    while (<F>)
	chomp;
	my($alias, $func) = split(/\t/);
	my(@extra);
	if ($func =~ /(\d+\.\d+\.\d+\.[\d+-]+)/g)
	    push(@extra, $1);
	    if ($peg ne "")
		push(@{$peg_words{$peg}}, $func, @extra);
    close(F);
    my $index_file = "$indexDir/external_alias_func";
	return;
    close(IDX);
    return @index_files;
