[Bio] / FigKernelScripts / index_sims.pl Repository:
View of /FigKernelScripts/index_sims.pl
Revision 1.12 - (download) (as text) (annotate)
Fri Jan 16 21:53:26 2009 UTC (10 years, 10 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, myrast_rel40, mgrast_dev_05262011, mgrast_dev_04082011, rast_rel_2010_0928, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_06072011, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, mgrast_dev_04012011, rast_rel_2009_07_09, rast_rel_2010_0827, myrast_33, rast_rel_2011_0928, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, HEAD
Bump id size.
# -*- perl -*-
# Public License.
#  Usage: index_sims [--table tablename] [--dir sims-dir] [ File1 File2 ... ]
#  If available, it uses the program index_sims_file
use strict;
use FIG;
use DBrtns;
use Tracer;
use Getopt::Long;
my $usage =  "Usage: $0 [--dbname database-name] [--table tablename] [--dir sims-dir] [ File1 File2 ... ]";
my $sims_db;
my $sims_dir;
my $new_sims_dir;
my $seeks_table  = "sim_seeks";
my $help = 0;
my( $sim_file, @sim_files );
my $rc = GetOptions("dir=s" => \$sims_dir,
		    "table=s" => \$seeks_table,
		    "dbname=s" => \$sims_db,
		    "help" => \$help);
$rc or die "$usage\n";
if ($help)
    print "$usage\n";
    exit 0;
if ($sims_db)
    $FIG_Config::db = $sims_db;
my $fig = new FIG;
my $dbf = $fig->db_handle;
my $seeks_file   = "$FIG_Config::temp/sims_seeks_tmp.$$";
# Traditional usage.
if ($sims_dir eq '')
    $sims_dir     = "$FIG_Config::data/Sims";
    $new_sims_dir = "$FIG_Config::data/NewSims";
print "Indexing sims_dir=$sims_dir new=$new_sims_dir seeks=$seeks_table\n";
print "Files: @ARGV\n";
#  Build the list of files to be indexed:
if ( @ARGV == 0 ) {
    Trace("Reading sim directory.") if T(2);
    opendir( SIMSDIR, $sims_dir ) || Confess("Could not open sims directory $sims_dir");
    @sim_files = map { "$sims_dir/$_" } grep { $_ !~ /^\./ } readdir( SIMSDIR );
    closedir( SIMSDIR );
    if ( $new_sims_dir and -d $new_sims_dir ) {
	opendir( SIMSDIR, $new_sims_dir ) || Confess("Could not open new sims $new_sims_dir");
	push @sim_files, map { "$new_sims_dir/$_" } grep { $_ !~ /^\./ } readdir( SIMSDIR );
    if ( @sim_files ) {
		$dbf->drop_table(   tbl  => $seeks_table );
		$dbf->create_table( tbl  => $seeks_table,
							flds => "id varchar(64), "
								  . "fileN INTEGER, "
								  . "seek INTEGER, "
								  . "len INTEGER"
} else {
    @sim_files = @ARGV;
my ( $v, $contigfilelist );
#  See if we can find the C program to do the indexing
my $use_prog = 0;
if (      open VERSION_PIPE, "index_sims_file -v |"
     and  $v = <VERSION_PIPE>
     and  close VERSION_PIPE
     and  chomp $v
     and  $v eq "1.00"
    $use_prog = 1;
my $nfiles = @sim_files;
my $n = 0;
#  For each file, find the seeks and load them into the database:
foreach $sim_file ( @sim_files ) {
    $n++;
    Trace("   Indexing sims file $sim_file ($n of $nfiles)") if T(2);
    my $fileN;
    if ( $fileN = $fig->file2N( $sim_file ) ) {
		# Check if sims file is zero length, and skip it if so.
		if ((-s $sim_file) == 0) {
			# Empty the file.
			open(SEEK_FH, ">$seeks_file");
			close(SEEK_FH);
		} else {
			( $use_prog &&
			 ( system( "index_sims_file  $fileN < $sim_file > $seeks_file" ) == 0 )
			|| index_sims_file( $sim_file, $fileN, $seeks_file )
			|| Confess("ERROR: index_sims failed on sim file $sim_file");
		if ( @ARGV > 0 ) {
			$dbf->SQL("DELETE FROM $seeks_table WHERE ( fileN = $fileN )");
		$dbf->load_table( tbl => $seeks_table, file => $seeks_file );
unlink( $seeks_file );
#  Index the database file:
if ( @ARGV == 0 ) {
	Trace("Indexing $seeks_table table.");
    $dbf->create_index( tbl  => $seeks_table,
			idx  => "${seeks_table}_id_ix",
			type => "btree",
			flds => "id"
    $dbf->vacuum_it( $seeks_table );
Trace("Sim index processing complete.") if T(2);
#  The perl version in case the C version fails:
sub index_sims_file {
    my( $file, $fileN, $seeks_file ) = @_;
    my( $line, $offset, $curr, $nxt_offset, $ln );
    open( SIMS,  "<$file" ) || return 0;
    open( SEEKS, ">$seeks_file") || ( close( SIMS ) && return 0 );
    $offset = tell SIMS;
    $line = <SIMS>;
    while ( defined( $line ) && ( $line =~ /^(\S+)/ ) ) {
		$curr = $1;
		while ( $line && ( $line =~ /^(\S+)/ ) && ( $1 eq $curr ) ) {
			$nxt_offset = tell SIMS;
			$line = <SIMS>;
		$ln = $nxt_offset - $offset;
		print SEEKS "$curr\t$fileN\t$offset\t$ln\n";
		$offset = $nxt_offset;
    close( SEEKS );
    close( SIMS );
    return 1;
1;
