[Bio] / FigKernelScripts / index_pins.pl Repository:
Log of /FigKernelScripts/index_pins.pl
Thu Jun 22 19:49:00 2006 UTC (13 years, 8 months ago) by olson
Changes since 1.2: +18 -5 lines
new pin indexer
Mon Mar 6 20:16:09 2006 UTC (13 years, 11 months ago) by olson
Changes since 1.1: +67 -43 lines
index the cutoff value too.
Fri Jan 27 17:39:52 2006 UTC (14 years ago) by olson
Index precomputed pins files.
