[Bio] / FigKernelScripts / index_nr.pl Repository:
Log of /FigKernelScripts/index_nr.pl
Mon Apr 16 21:42:31 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.1: +15 -2 lines
compute length btree also
Fri Apr 13 20:55:13 2007 UTC (12 years, 8 months ago) by olson
create btree nr index
