[Bio] / FigKernelScripts / index_contigs.pl Repository:
Log of /FigKernelScripts/index_contigs.pl
Fri Jan 21 20:42:04 2011 UTC (9 years, 2 months ago) by redwards
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.11: +6 -2 lines
not reopening a file twice!
CVS Tags: caBIG-05Apr06-00, caBIG-13Feb06-00, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_release_2008_09_29
Changes since 1.10: +17 -0 lines
Thu Jun 9 05:51:06 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.9: +34 -33 lines
Mon Apr 25 15:29:41 2005 UTC (14 years, 11 months ago) by olson
Add compute_contig_md5 as a standalone tool to compute the checksum of a set of contigs.
Fix index_contigs.pl to produce the correct nucleotide counts in the signature file.
Sun Apr 10 00:15:17 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.7: +4 -1 lines
addition to gff2seed
Tue Mar 8 21:06:04 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.6: +110 -8 lines
Add support for computing MD5 checksums for contigs and genomes.
The checksum of a genome is defined as the checksum of its signature file. The signature
file consists of tab-separated lines, one for each contig, ordered by the contig id.
Each line contains the contig ID, the length of the contig in nucleotides, and the
MD5 checksum of the nucleotide data, with uppercase letters forced to lower case.
The signature file is written by index_contigs to
The genome's md5 checksum is written by index_contigs to <genomedir>/MD5SUM.
The md5.c code here is extracted from the Perl Digest::MD5 module. We use the perl
configuration to build it so that it will work correctly on 64-bit architectures.
Tue Aug 24 22:11:50 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.5: +366 -72 lines
Gary Olsen's optimized database loading code.
This probably needs to be tweaked to use the full path (FIG_Config::bin/<app>), but I
want to get this committed today.
Fri Jan 2 19:36:46 2004 UTC (16 years, 3 months ago) by overbeek
Changes since 1.4: +3 -1 lines
index_contigs should go to organisms directory to get full set
Sun Dec 28 17:11:29 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.3: +3 -3 lines
cleanup issues relating to large numbers of partial genomes
Fri Dec 26 04:25:44 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.2: +18 -12 lines
defer indexes until after complete load
Sat Dec 20 15:19:21 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.1: +6 -0 lines
for incremental additions to the DB, delete old versions of things
Mon Dec 1 20:46:40 2003 UTC (16 years, 4 months ago) by efrank
Makefile:
All the rest:
