[Bio] / FigKernelScripts / index_anno_clearinghouse.pl Repository:
View of /FigKernelScripts/index_anno_clearinghouse.pl
Revision 1.3 - (download) (as text) (annotate)
Wed Nov 7 15:40:38 2007 UTC (12 years ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Changes since 1.2: +34 -2 lines
multiple id support, build fixes
use strict;
use NRTools;
use FIG;
use DB_File;
# Create the btree indexes on an annotation clearinghouse.
# anno.btree: id => annotation
# org.btree: id => organism
# orgnum.btree: orgname => numeric id
# orgname.btree:  numeric id => orgname
my $usage = "index_anno_clearinghouse SEED-directory target-directory";
@ARGV == 2 or die  $usage;
my $dir_seed = shift;
my $dir_target = shift;
&FIG::verify_dir($dir_target);
my $dir_nr = "$dir_target/NR";
my %NR_files;
$DB_BTREE->{flags} = R_DUP;
# Scan inputs.
print "Scan NR\n";
scan_NR_dir(\%NR_files, $dir_nr);
print "Scan SEED\n";
scan_seed_dir(\%NR_files, $dir_seed);
#scan_seed_dir(\%NR_files, $dir_seed, { limit => 10 });
# Create btrees. Empty existing files if present.
my $func_file = "$dir_target/anno.btree";
my $org_file = "$dir_target/org.btree";
my $orgname_file = "$dir_target/orgname.btree";
my $orgnum_file = "$dir_target/orgnum.btree";
my $alias_file = "$dir_target/alias.btree";
my $next_orgnum = 1;
-f $func_file and unlink($func_file);
-f $org_file and unlink($org_file);
-f $orgname_file and unlink($orgname_file);
-f $orgnum_file and unlink($orgnum_file);
-f $alias_file and unlink($alias_file);
my %func;
my $func_tie = tie %func, 'DB_File', $func_file, O_RDWR | O_CREAT, 0666, $DB_BTREE;
$func_tie or die "Cannot create bree $func_file: $!\n";
my %org;
my $org_tie = tie %org, 'DB_File', $org_file, O_RDWR | O_CREAT, 0666, $DB_BTREE;
$org_tie or die "Cannot create bree $org_file: $!\n";
my %orgname;
my $orgname_tie = tie %orgname, 'DB_File', $orgname_file, O_RDWR | O_CREAT, 0666, $DB_BTREE;
$orgname_tie or die "Cannot create bree $orgname_file: $!\n";
my %orgnum;
my $orgnum_tie = tie %orgnum, 'DB_File', $orgnum_file, O_RDWR | O_CREAT, 0666, $DB_BTREE;
$orgnum_tie or die "Cannot create bree $orgnum_file: $!\n";
my %alias;
my $alias_tie = tie %alias, 'DB_File', $alias_file, O_RDWR | O_CREAT, 0666, $DB_BTREE;
$alias_tie or die "Cannot create bree $alias_file: $!\n";
for my $ent (values %NR_files)
    if ($ent->{type} eq 'seed_org')
	my $af = "$ent->{path}/assigned_functions";
	my $org = &FIG::file_head("$ent->{path}/GENOME", 1);
	chomp $org;
	my $orgnum = get_orgnum($org);
	print "Process $ent->{path} ($org)\n";
	next unless -f $af;
	my %seen;
	open(A, "tac $af|") or die "cannot open tac $af pipe: $!\n";
	while (<A>)
	    if (/^(fig\|\d+\.\d+\.peg\.\d+)\t(.*)/)
		next if $seen{$1};
		$func{$1} = join($;, 'SEED', $2);
		$org{$1} = $orgnum;
		$seen{$1}++;
	close(A);
    else
	my $org_file = "$ent->{path}/org.table";
	my $func_file = "$ent->{path}/assigned_functions";
	if (open(OF, "<$org_file"))
	    print "Process $org_file\n";
	    while (<OF>)
		chomp;
		my($id, $org) = split(/\t/);
		my $val = get_orgnum($org);
		$org{$id} = $val;
		# map { $org{$_} = $val } map_id($id);
	    close(OF);
	if (open(FF, "<$func_file"))
	    print "Process $func_file\n";
	    while (<FF>)
		chomp;
		my($id, $func) = split(/\t/);
		my $val = join($;, $ent->{name}, $func);
		$func{$id} = $val;
		#map { $func{$_} = $val } map_id($id);
		if ($id =~ /^[^|]+\|(.*)/)
		    $alias{$1} = $id;
	    close(FF);
    $func_tie->sync();
    $org_tie->sync();
    $orgname_tie->sync();
    $orgnum_tie->sync();
    $alias_tie->sync();
sub get_orgnum
    my($org) = @_;
    my $num = $orgnum{$org};
    if (!defined($num))
	$num = $next_orgnum++;
	$orgnum{$org} = $num;
	$orgname{$num} = $org;
    return $num
sub map_id
    my($id) = @_;
	return ($id, $1);
    else
	return ($id);
