[Bio] / FigKernelScripts / import_external_sequences_step1.pl Repository:
Log of /FigKernelScripts/import_external_sequences_step1.pl
Changes since 1.7: +17 -0 lines
Revision 1.7 - (view) (download) (as text) (annotate) - [selected]
Fri Apr 22 13:02:15 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.6: +11 -0 lines
current external update procedure set
Fri Apr 22 12:50:43 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.5: +5 -2 lines
fixes to import_external_sequences_step1
Tue Apr 19 03:01:45 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.4: +20 -42 lines
various fixes to package/install annotations
Fri Mar 11 16:03:19 2005 UTC (15 years ago) by overbeek
Changes since 1.3: +2 -1 lines
Fixed to comply with changed `compute_changed_ids_for_nrs` syntax. -- /gdp
Wed Feb 9 17:04:44 2005 UTC (15 years, 1 month ago) by overbeek
Corrected typos. -- /gdp
Tue Feb 8 20:27:15 2005 UTC (15 years, 1 month ago) by overbeek
Changes since 1.1: +10 -1 lines
import_external_sequences fixes
Tue Feb 8 20:04:38 2005 UTC (15 years, 1 month ago) by overbeek
Diff to selected 1.7
untested import_external_sequences_step1
