[Bio] / FigKernelScripts / gff2Ontology.pl Repository:
Log of /FigKernelScripts/gff2Ontology.pl
Thu Nov 10 20:16:51 2005 UTC (14 years, 3 months ago) by efrank
CVS Tags: caBIG-00-00-00
Changes since 1.2: +3 -4 lines
mv cv files from Global to Global/CV.
Thu Oct 27 19:04:29 2005 UTC (14 years, 3 months ago) by efrank
Changes since 1.1: +21 -3 lines
by default, look for input GO.terms_ids_obs in Data/Global but allow -go_file
to override.  don't blame me- that's what GO calls the file.
idea is that we're following robs pattern and sometime later there may be
a "download GO" button that fetches latest version into Global and then
gff2Ontology -make_go_triplet_file can build new controlled vocab search
table that is used by cv.cgi.  (all of that works except for the button)
note- it's a separate issue to run gff2Ontology on a gff to rip out the
GO and put it into the Seed as controlled vocab.
Thu Oct 27 16:32:54 2005 UTC (14 years, 3 months ago) by efrank
# A little misnamed as this only handle's GO at the moment.
# Maybe this should just disappear and be internalized by gff2Seed??
# Pull the Ontology information from column9 and insert it as
# controlled vocabulary for the relevant PEGs. We assume the
# GFF has already been loaded into the Seed instance.
# Running this modifies the attributes tables and files.  It does NOT
# zero anything before running, so do that by hand if needed.
