[Bio] / FigKernelScripts / get_translations.pl Repository:
Log of /FigKernelScripts/get_translations.pl
Wed Apr 26 22:08:03 2006 UTC (14 years, 1 month ago) by overbeek
get_translations can take PEG ids from STDIN
Wed Oct 20 17:39:11 2004 UTC (15 years, 7 months ago) by overbeek
add get_translations
