[Bio] / FigKernelScripts / get_translations.pl Repository:
Log of /FigKernelScripts/get_translations.pl
Links to mgrast_dev_08112011: (view) (download) (as text) (annotate)
Wed Apr 26 22:08:03 2006 UTC (14 years, 2 months ago) by overbeek
get_translations can take PEG ids from STDIN
Wed Oct 20 17:39:11 2004 UTC (15 years, 8 months ago) by overbeek
Diff to selected 1.3
add get_translations
