[Bio] / FigKernelScripts / get_ss_connections.pl Repository:
Log of /FigKernelScripts/get_ss_connections.pl
Fri Jul 24 02:13:15 2009 UTC (10 years, 4 months ago) by redwards
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.11: +3 -0 lines
only call if not in a ss
Tue Apr 17 20:08:29 2007 UTC (12 years, 7 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_release_2008_09_29
Changes since 1.10: +5 -0 lines
don't crash on missing SS
Wed Apr 11 17:47:15 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.9: +56 -10 lines
rollup of metagenome server changes
Mon Feb 5 21:21:10 2007 UTC (12 years, 9 months ago) by redwards
Changes since 1.8: +3 -3 lines
adding fake variants, bugger should check it works first!
Mon Feb 5 21:19:01 2007 UTC (12 years, 9 months ago) by redwards
Changes since 1.7: +8 -0 lines
Mon Feb 5 20:10:11 2007 UTC (12 years, 9 months ago) by redwards
Changes since 1.6: +1 -0 lines
correcting insertion of genomes into subsystems
Mon Feb 5 18:29:56 2007 UTC (12 years, 9 months ago) by redwards
Changes since 1.5: +21 -1 lines
Adding roles to ss
Tue Jul 25 00:53:08 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.4: +3 -3 lines
RAE: changing default params
Tue Jul 25 00:50:37 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.3: +20 -3 lines
RAE: dereferencing hash, adding more printout
Wed Jun 28 15:53:56 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.2: +14 -3 lines
RAE: adding peg output
Tue Jun 6 01:06:09 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.1: +9 -1 lines
RAE: adding one more function i forgot i needed
Tue Jun 6 00:58:23 2006 UTC (13 years, 5 months ago) by overbeek
RAE: Initial release of a new interface that plots a heatmap of proteins that are in subsystems. The initial release is just based on a single attribute (ss_connections), but I hope to extend it to mapping on different things. Makes pretty tables though!
