[Bio] / FigKernelScripts / get_pubmed_journals.pl Repository:
Log of /FigKernelScripts/get_pubmed_journals.pl
Tue Mar 20 18:23:33 2007 UTC (13 years ago) by hwang
Changes since 1.4: +3 -3 lines
update comment that this is for peg curation
Wed Feb 28 15:44:21 2007 UTC (13 years, 1 month ago) by hwang
Files to get journal information from PubMed
Tue Feb 27 20:38:15 2007 UTC (13 years, 1 month ago) by hwang
Changes since 1.2: +11 -4 lines
Modified script to weed out Genome papers
Tue Feb 27 00:53:50 2007 UTC (13 years, 1 month ago) by hwang
Changes since 1.1: +1 -4 lines
fixed syntax error
Mon Aug 14 19:25:10 2006 UTC (13 years, 7 months ago) by hwang
Given gi/sp/GeneID get the pubmed journals
