[Bio] / FigKernelScripts / get_families_final.pl Repository:
Log of /FigKernelScripts/get_families_final.pl
Fri Mar 21 18:11:18 2014 UTC (5 years, 8 months ago) by overbeek
Changes since 1.2: +61 -0 lines
fixed documentation
Fri Mar 7 16:04:44 2014 UTC (5 years, 9 months ago) by overbeek
Changes since 1.1: +15 -4 lines
handle 1-char functions
Thu Jan 30 20:20:42 2014 UTC (5 years, 10 months ago) by overbeek
add orthoMCL equiv
