[Bio] / FigKernelScripts / get_coupling_values.pl Repository:
Log of /FigKernelScripts/get_coupling_values.pl
Thu Aug 12 18:41:35 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.1: +8 -1 lines
Add figfam coupling computation
Thu Aug 12 16:15:05 2010 UTC (9 years, 7 months ago) by overbeek
compute functional coupling scores for co-occ and co-reg
