[Bio] / FigKernelScripts / get_coupling_values.pl Repository:
Log of /FigKernelScripts/get_coupling_values.pl
Tue Sep 14 18:39:54 2010 UTC (9 years, 6 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.2: +0 -4 lines
get rid of extraneous routine
Thu Aug 12 18:41:35 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.1: +8 -1 lines
Add figfam coupling computation
Thu Aug 12 16:15:05 2010 UTC (9 years, 7 months ago) by overbeek
Diff to selected 1.2
compute functional coupling scores for co-occ and co-reg
