[Bio] / FigKernelScripts / genome_peg_dna.pl Repository:
Log of /FigKernelScripts/genome_peg_dna.pl
Fri Nov 2 17:24:05 2007 UTC (12 years ago) by golsen
Changes since 1.2: +108 -51 lines
Extensive modifications to allow more options, and handle large genomes
by not reading all the contigs into memory at once.
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
Tue Mar 15 23:03:08 2005 UTC (14 years, 8 months ago) by golsen
Tool to dump peg DNA sequences
