[Bio] / FigKernelScripts / generate_partitions_worker.pl Repository:
Log of /FigKernelScripts/generate_partitions_worker.pl
Thu Nov 11 17:39:53 2010 UTC (9 years, 6 months ago) by disz
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
FigFam 6 digit problem
Thu Oct 8 19:00:18 2009 UTC (10 years, 7 months ago) by arodri7
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.2: +38 -8 lines
commit change
Mon Dec 22 07:13:27 2008 UTC (11 years, 5 months ago) by arodri7
CVS Tags: rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.1: +38 -12 lines
added changes to update procedure
Thu Jan 31 20:36:12 2008 UTC (12 years, 4 months ago) by overbeek
code to generate partitions for FIGfams
