[Bio] / FigKernelScripts / generate_partitions_worker.pl Repository:
View of /FigKernelScripts/generate_partitions_worker.pl
Thu Jan 31 20:36:12 2008 UTC (12 years, 5 months ago) by overbeek
CVS Tags: rast_rel_2008_06_18, rast_rel_2008_06_16, rast_rel_2008_12_18, rast_rel_2008_07_21, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_09_30, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, mgrast_rel_2008_0625, rast_rel_2008_10_09, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, mgrast_rel_2008_1110, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_08_07
code to generate partitions for FIGfams
use FIG;
my $fig = new FIG;
use FIGO;
my $figO = new FIGO;
use strict;
my $sim_thresh = 1.0e-10;
my($usage,$fams,$outD,$doneF,$proc);
$usage = "usage: generate_partition_worker Families OutDir DoneF Process < FIGfams > Partitions";
 ($fams = shift @ARGV) && open(FAMS,"<$fams") &&
 ($outD = shift @ARGV) &&
 ($doneF = shift @ARGV) &&
 ($proc = shift @ARGV)
    || die $usage;
open(OUT,">>$outD/$proc") || die "could not open $outD/$proc";
my $ofh = select OUT; $| = 1; select $ofh;
my %done_fam;
foreach $_ (`cat $doneF`)
    chop;
    $done_fam{$_} = 1;
my(%fam_to_pegs,%peg_to_fams);
while (defined($_ = <FAMS>))
    if ($_ =~ /^(\S+)\t(\S+)/)
	my($fam,$peg) = ($1,$2);
	if ((! $fig->is_deleted_fid($peg)) && (! $done_fam{$fam}))
	    push(@{$fam_to_pegs{$fam}},$peg);
	    push(@{$peg_to_fams{$peg}},$fam);
close(FAMS);
#print STDERR "loaded FIGfamsd\n";
my $peg;
while (defined($_ = <STDIN>))
    if (($_ =~ /(FIG\d{6})/) && (! $done_fam{$1}))
	print STDERR "$proc processing $1\n";
	my $ff = $1;
	my $todo = { $ff => 1 };
	my $loaded_fams = {};
	my $state = [$fig,$figO,\%done_fam,$todo,$loaded_fams,\%fam_to_pegs,\%peg_to_fams,$sim_thresh];
	&load_fam($ff,$state);
	my @todo;
	while ((@todo = keys(%$todo)) > 0)
	    my $fam = $todo[0];
	    &process($fam,$state);
#	    print STDERR &Dumper(['todo',$todo]);
sub load_fam {
    my($ff,$state) = @_;
    my($fig,$figO,$done_fam,$todo,$loaded_fams,$fam_to_pegs,$peg_to_fams,$sim_thresh) = @$state;
    my $loaded_fam = $loaded_fams->{$ff};
    if (! $loaded_fam)
	my $pegs = $fam_to_pegs{$ff};
	my @clean_pegs = ();
	foreach my $peg (@$pegs)
	    my $featureO = new FeatureO($figO,$peg);
	    if ($featureO && (! $fig->possibly_truncated($peg)) && (! $featureO->possible_frameshift))
		push(@clean_pegs,$peg);
	my @sims = ();
	foreach my $sim ($fig->sims(\@clean_pegs,100000,$sim_thresh,'fig'))
	    my $match1 = $sim->e1 - $sim->b1;
	    my $match2 = $sim->e2 - $sim->b2;
	    if ((($match1 / $sim->ln1) > 0.7) &&
		(($match2 / $sim->ln2) > 0.7))
		push(@sims,$sim);
	my $others_not_in_fam = {};
	my $other_fams        = {};
	my $worst_hit = 1000;
	foreach my $sim (sort { ($a->id1 cmp $b->id1) or ($b->bsc <=> $a->bsc) } @sims)
	    my $id1 = $sim->id1;
	    my $id2 = $sim->id2;
	    my $in  = $peg_to_fams{$id2};
	    my $matched1 = ($sim->e1 + 1) - $sim->b1;
	    if (! $in)
		$others_not_in_fam->{$id2} = 1;
	    else
		foreach my $fam_in (@$in)
		    if ($fam_in eq $ff)
#			print STDERR &Dumper([$worst_hit,$sim->bsc/$matched1]);
			if (((! defined($worst_hit)) || (($sim->bsc / $matched1) < $worst_hit)))
			    $worst_hit = sprintf("%5.3f",($sim->bsc / $matched1));
		    else
			if (! $other_fams->{$fam_in})
#			    print STDERR "$ff - $fam_in $id1 $id2\n";
			$other_fams->{$fam_in} = 1;
	$loaded_fams->{$ff} = [$worst_hit,$other_fams,$others_not_in_fam];
#   print STDERR &Dumper(["loaded $ff",$loaded_fams->{$ff}]);
sub process {
    my($fam,$state) = @_;
    my $loaded = $loaded_fams->{$fam};
    my($worst_hit,$other_fams,$others_not_in_fam) = @$loaded;
    my @contained_in = ();
    my @not_contained_in = ();
    foreach my $famO (keys(%$other_fams))
	&load_fam($famO,$state);
	my $other_fams2 = $loaded_fams->{$famO}->[1];
	my $contained = 1;
	foreach my $famO2 (keys(%$other_fams2))
	    if (($famO2 ne $fam) && (! $other_fams->{$famO2}))
		$contained = 0;
	if ($contained)
	    push(@contained_in,$famO);
	else
	    push(@not_contained_in,$famO);
    my $set_to_write = [$fam,@contained_in];
    &write_set($set_to_write,$state,\@not_contained_in);
    foreach my $famD (@$set_to_write)
	if ($todo->{$famD}) { delete $todo->{$famD} }
	$done_fam->{$famD} = 1;
    foreach my $famO (@not_contained_in)
	if (! $done_fam->{$famO})
	    $todo->{$famO} = 1;
sub write_set {
    my($set,$state,$not_contained_in) = @_;
    my %all_pegs;
    my @fams_with_worst = ();
    foreach my $fam (@$set)
	push(@fams_with_worst,"$fam,$worst_hit");
	my $pegs = $fam_to_pegs->{$fam};
	foreach my $peg (@$pegs,keys(%$others_not_in_fam))
	    $all_pegs{$peg} = 1;
    foreach my $fam (@$not_contained_in)
    foreach $peg (sort { &FIG::by_fig_id($a,$b) } keys(%all_pegs))
	print OUT "$peg\n";
    print OUT "//\t",join(" ",@fams_with_worst),"\n";
