[Bio] / FigKernelScripts / generate_intergenic_blocks.pl Repository:
Log of /FigKernelScripts/generate_intergenic_blocks.pl
Sun May 15 12:00:19 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.1: +25 -25 lines
fix to generate_intergenic_blocks
Sun May 15 11:49:37 2005 UTC (14 years, 9 months ago) by overbeek
minor fixes in computing functional coupling
