[Bio] / FigKernelScripts / generate_genome_feature_tables_for_sprout.pl Repository:
Log of /FigKernelScripts/generate_genome_feature_tables_for_sprout.pl
Changes since 1.15: +17 -0 lines
Tue Aug 16 20:23:01 2005 UTC (14 years, 6 months ago) by parrello
Accidentally removed a useless tab.
Tue Jul 26 20:15:53 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.13: +112 -112 lines
Fixed indenting.
Thu Jun 16 18:27:08 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.12: +0 -18 lines
routines to support derivation of sprout data
Sat Jun 11 15:11:37 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.11: +28 -20 lines
fixes to Sprout data generation
Mon Jan 24 19:18:38 2005 UTC (15 years ago) by overbeek
correct concept of user assign in make_annotations_for_sprout
Tue Jan 18 22:15:42 2005 UTC (15 years, 1 month ago) by overbeek
Changes since 1.9: +34 -41 lines
fixes to generation of sprout features
Tue Jan 18 19:09:03 2005 UTC (15 years, 1 month ago) by overbeek
fix aliases for Sprout
Tue Jan 18 19:02:29 2005 UTC (15 years, 1 month ago) by overbeek
Changes since 1.7: +5 -2 lines
Wed Jan 5 20:24:14 2005 UTC (15 years, 1 month ago) by overbeek
minor fixes to subsys.cgi and tree_utilities.pm
Fri Dec 10 19:50:48 2004 UTC (15 years, 2 months ago) by overbeek
add column to IsMadeUpOf
Tue Dec 7 19:32:39 2004 UTC (15 years, 2 months ago) by overbeek
reorder columes in NMPDR Feature table
Mon Dec 6 21:51:51 2004 UTC (15 years, 2 months ago) by overbeek
Changes since 1.3: +10 -2 lines
produce translations when making data for Sprout
Sat Dec 4 22:10:10 2004 UTC (15 years, 2 months ago) by overbeek
fixes to generation of sprout data
Sun Oct 24 17:36:02 2004 UTC (15 years, 3 months ago) by overbeek
Allow Data directory as input to build_nr_sources
Fri Oct 15 15:42:51 2004 UTC (15 years, 4 months ago) by overbeek
add generate_genomes_and_features_for_sprout
