[Bio] / FigKernelScripts / generate_GO_attributes.pl Repository:
Log of /FigKernelScripts/generate_GO_attributes.pl
Fri Dec 1 23:22:45 2006 UTC (13 years, 2 months ago) by overbeek
add GO attribute genertation
