[Bio] / FigKernelScripts / genbank2gff3.pl Repository:
Log of /FigKernelScripts/genbank2gff3.pl
Mon Dec 5 18:56:37 2005 UTC (14 years, 6 months ago) by olson
Fri Aug 12 01:14:41 2005 UTC (14 years, 9 months ago) by overbeek
minor bug fix on ids
Wed Aug 10 15:33:59 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.2: +6 -4 lines
Getting the ID right
Wed Aug 10 15:11:28 2005 UTC (14 years, 9 months ago) by overbeek
Initial release
Wed Aug 10 15:00:14 2005 UTC (14 years, 9 months ago) by overbeek
Diff to selected 1.5
Initial release
