[Bio] / FigKernelScripts / genbank2gff3.pl Repository:
Log of /FigKernelScripts/genbank2gff3.pl
Links to mgrast_release_3_0_1: (view) (download) (as text) (annotate)
Fri Aug 12 01:14:41 2005 UTC (14 years, 11 months ago) by overbeek
minor bug fix on ids
Wed Aug 10 15:33:59 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.2: +6 -4 lines
Getting the ID right
Wed Aug 10 15:11:28 2005 UTC (14 years, 11 months ago) by overbeek
Initial release
Wed Aug 10 15:00:14 2005 UTC (14 years, 11 months ago) by overbeek
Diff to selected 1.5
Initial release
