[Bio] / FigKernelScripts / flatten_fasta.pl Repository:
Log of /FigKernelScripts/flatten_fasta.pl
Links to mgrast_release_3_0_1: (view) (download) (as text) (annotate)
Mon Dec 26 03:37:37 2005 UTC (14 years, 3 months ago) by overbeek
add some minor utilities to flatten/unflatten fasta files
