[Bio] / FigKernelScripts / fix_ext_funcs.pl Repository:
Log of /FigKernelScripts/fix_ext_funcs.pl
Links to caBIG-13Feb06-00: (view) (download) (as text) (annotate)
Thu Jun 16 18:27:08 2005 UTC (14 years, 5 months ago) by overbeek
routines to support derivation of sprout data
